Stevebx's avatar
Stevebx
A home electrical question...
Thought I'd check here as there are a lot of experts that help out. I bought a place that has a light over a stairway, switch at bottom of stairs, switch at top. I noticed that the light is still on, very dim, when it should be off. I haven't wired a 3 way switch before so don't know what to look for.
  • Stevebx,
    Two questions, if I may?
    Just out of curiosity, what type of bulb is in the fixture: incandescent, fluorescent, compact fluorescent or LED?
    While technically a bulb should be completely dark when it's "off", I've seen some that seem to glow for a long time afterward, especially the fluorescents and some LEDs. In fact, we have an LED sign which when shut off, you can still see a slight glow coming from the LEDs when the room is otherwise completely dark. If I pull the plug, they go dark. Apparently just the potential across the bulbs/power supply is enough to allow a trickle current through them so they barely illuminate. I never observed this type of problem with an incandescent bulb.
    Second question, while unusual for a stairway, is there a dimmer control on one of the switches?
    ~Rick
  • Bad switch or maybe a dimmer switch was installed are likely candidates. Miswired or failed wiring is also possible.
  • 3_tons's avatar
    3_tons
    Explorer III
    Heres a great tutorial:
    https://www.familyhandyman.com/electrical/wiring-switches/how-to-wire-a-threeway-switch/
    If the light is on dim, it may be the sign of a failing switch and power back feeding from ground.
Having RV issues? Connect with others who have been in your shoes.24,303 PostsLatest Activity: Aug 21, 2025
