happycamper002
Mar 03, 2017Explorer
wa8yxm wrote:
. . . Space heaters are typically 1500 watt, about 12.5 amps as I recall without doing the division.. Confirmed by mutliplication.
Nest there is that good old ROUND hole/pin. the safety ground.
Recommendation:
Check heater, an ohmmeter measuring between the flat pins and the round pin may be good enough to find a ground fault. . . .
With only one problem: not all small space heaters have ground pin, hence, no need for a round hole.
Most of them are double insulated as in made of plastic.
All the best.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
