MEXICOWANDERER
Mar 12, 2015Explorer
Chemical supply and lab supply stores offer lab grade old fashioned tubular column thermometers. Some are expanded scale like a scope of 20F to 80F. Resolution is incredible. And I will stake my rear-end on the fact these guys are not play toys. THEY CAN NOT BECOME INACCURATE - EVER.
I use my column thermometers as B.S. detectors. A glance every day or two will verify or discredit a bargain digital thermometer. I worked up a system for a really sweet elderly couple. The man had ultra temp sensitive medication. I sold him one of my extras then scrounged enough foam board and aerosol foam spray to make a second container for the med. The second container buys a lot of time in case of a refrigeraton malfunction.
N.I.S.T. grade thermometers are far too accurate for your needs. +- 1F is even getting a bit carried away. But whatever you get you can't afford for it to start telling fairy tales
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 17, 2026
