MEXICOWANDERER
May 02, 2019Explorer
If someone suspects they know of a simpler AGM battery protocol than
Connect to a charging source that maintains 14.5 volts and can restore to 100% charged state from 50% state of charge in 6.5 hours and you have found "The Perfect Charger" for AGM. Timer controlled limit would safeguard the system. This would not be enough control voltage wise for elk hunting or Colorado river camping in July.
I am tasking myself with finding variable resistance pads for use with Megawatts for use with auto voltage control from -15F to 115F It eliminates manual switching. The thermistor would be lost if the battery were to become useless.
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
