pianotuna
Jun 23, 2016Nomad III
Hi SMK,
Yes, I'm using the load support feature of the Magnum--but it is drawing 35 amps. I can't keep that up all day long.
I tried double conversion last summer and promptly blew the reverse polarity fuses on the PD 40 amp. That did not happen when I had the Cobra 2500 watt MSW unit--but then I did not run the roof air from it either.
I've been wiring around the Magnum as there was more voltage drop with it that without it. I guess I should have insisted on more than #10 wire to and from the AC side of the Magnum.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 18, 2026
