Janss's avatar
Janss
Explorer II
Dec 15, 2017
ABS light
The anti-lock brake system light on my dash comes on occasionally and randomly. It doesn't come on every time I drive. It may not come on for hundreds of miles, like all the way from Sedona to Oregon. Then on the way back, it just happens to come on. After I stop and start the engine again it's not on. Today was the first time the light turned off while still driving (after it randomly turned on while driving).
I just had the MH to a Chevy dealer for that and other stuff. They tested the ABS system and said it's working fine and there were no error codes. And of course the light was not on while at the dealer. They had no other advice for me.
I'm not at all knowledgeable about auto mechanics.
So I ask anyone here for ideas. I guess I feel a little more comfortable that the dealer checked the system. But still a little uncomfortable. Could it just be a loose wire in the dash or in the system, or a fuse problem?
  • My ABS light was a bit intermittent for a few years.
    Have not seen it since the alternator gave up and exchanged for new.
  • I had problems with my ABS on my E150. Replaced both front wheel speed sensors (about $40) and the problems went away.
  • There are code readers that include ABS codes as well as emission codes. HF has a reasonably priced one for the occasional user. Keep it in the MH until the light comes back on and plug it in without turning the MH off. Knowing the code(s) can save serious money.
  • j-d's avatar
    j-d
    Explorer II
    Trying to pull everybody's responses together...
    Because you live in beautiful dry Sedona... I'm thinking you might be less likely to have dry rust around the front sensors. By "dry" I mean NOT in a closed, oily lubricated area like the rear axle.
    Based on that, I'd still like to see if you an access the sensor for the Rear Wheels. The RockAuto site shows NO sensors for W-series, but does show them for P-series (the bread trucks, UPS/FedEx trucks, etc. Here's a picture of one.
    The Sensor part of it is below that reddish O-Ring that seals it into the lubricated environment which could be a rear axle (like Ford) or a transmission (that seems to be the case with Chevy/Workhorse). The connector is probably two-wire (if similar to Ford) and goes into the oval shaped hole. The little triangular "shark fin" sticking up latches the connector.
    The RockAuto lookup (again for P-series, they don't show them for W) shows two of these, transmission mounted, identical, one for Input Rotation the other for Output Rotation. Output would be the same as the front of the Driveshaft. Ford uses the Differential for its sensor position, equivalent to Output on Chevy, probably same on Workhorse.
    I'm hoping an RV Tech jumps in on this. I can see how the Ford style, axle mounted, can pick up "dross" from wear on the differential gears. Transmission pans often have a magnet in them to trap that dross, but I suppose a transmission-mounted sensor (sometimes called VSS for Vehicle Speed Sensor) could still trap dross even with a pan magnet.
    In the absence of more info, I'm for finding the VSS (one or two on transmission, maybe one on axle). Clean the area around it/them, then pull, clean, put grease on O-Ring, reinstall. Cost is $zero. See if anything changes.
  • Thanks for the additional comments.
    j-d, I really do mean I lack knowledge and am not a DIYer in auto mechanics. Well, I can check the oil and add some fluids :) I do appreciate your time and effort to educate me.
    I wish I would have asked about this before I picked up my coach from the shop. Oh well, I'm sure I'll have another chance sometime to talk with a mechanic who is willing to delve deeper than this dealer. As noted, now I will know what to discuss and ask for.
    bucky...Interesting idea about the code reader. I had to look all that up. I'm going to look for the plug outlet in the MH.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
