Greg_The_Hammer's avatar
May 02, 2014
ABS vs PVC DWV plumbing
I have been RVing for going on 20 years. Also, I have been involved with residential contracting for quite some time as well. Many years ago, ABS replaced copper as the preferred material for plumbing the drain systems in residences. Then maybe 20 years or so ago, PVC replaced ABS as the preferred material for DWV systems, and is in use everywhere today, EXCEPT in RV's. The RV manufacturers seem to have stuck with ABS for some reason.
Does anyone have knowledge as to the reason they continue to use ABS rather than PVC? Is it less susceptible the vibration rigors of the open road? Is it less prone to rupture from freezing? Is it less brittle when cold? There must be a bona fide reason they don't use PVC, which is much more readily available.
I'm about to replace a ruptured section of ABS with PVC, unless there is a compelling reason not to. Thoughts?
Having RV issues? Connect with others who have been in your shoes.24,316 PostsLatest Activity: Sep 13, 2025
