BFL13
Nov 14, 2018Explorer II
Mex 40 amps of solar means you have about 40/8.2 x 130 = 634w array pointed directly at a high sun.
You can't get constant amps with solar unless you can keep the array pointed and tilted just right as the sun goes by while also going up and down.
However, it remains valid that you can follow your shot of generator charging with solar for the rest of the day in hopes that will get the batteries "full" before dark.
You can extend the gen time high amps when you know the daylight time after that will be short.
Having RV issues? Connect with others who have been in your shoes.24,388 PostsLatest Activity: May 21, 2026
