MEXICOWANDERER's avatar
Aug 21, 2014
CHARGING TERMS Bulk/Absorbsion/Float
Lots of confusion about these three terms. Let's simplify things a little.
We have a TWO STAGE CHARGER. The main charger and a float. Not a three stage, that's a bunch of marketing hooey.
The MAIN charger has a VOLTAGE LIMITED point. The voltage rises to this limit point in volts then stays there for god only knows how long before voltage is changed to a much lower maintenance value for maintaining the battery in hibernation.
Let's keep temperature compensation back behind the barricades on this one. This is a simple accurate explanation.
You connect the charger to the battery and turn it on.
As long as the battery is charging and the voltage is rising, slow or fast HAS NOT REACHED THAT AMBIGUOUS pre-determined and preset voltage set point IT IS CALLED BULK CHARGING.
The voltage keeps rising and bingo, it reaches the voltage set point whatever the hell the nut farm slide rule boys at the manufacturer has determined to be the maximum voltage charge point.
WE NOW CALL THE CHARGING PROCESS "ABSORBSION" and forget about the word BULK.
The voltage limit has been reached. How LONG the voltage stays steady and the battery is allowed to charge is anyone's guess - Groucho, Harpo, and Zeppo now have control of the charging process. WHEN, HOW LONG? I ask. How long does the battery stay at "absorbsion" voltage limit before dropping down into float?
The absorbsion VOLTAGE LIMIT (setting) and time spent at this voltage limit...
SHOULD HAVE THE ABILITY TO BE ADJUSTED BY A USER
But they don't have that ability. I would like to see one that does...
This is like a car that automatically goes 37 miles an hour. In bumper to bumper rush hour or across the wilds of West Texas.
But knowing what your SMART CHARGER
CANNOT POSSIBLY DO
Should be job one. Learn about the mess that is under your counter and the gyro gearloose smart chargers that are purported to be "better".
INTELLIGENT battery charging DEMANDS adjustable voltage set points and ADJUSTABLE time spent at absorbsion.
Good luck trying to find these features.
Press a button, take a pill, Don't Worry be Happy!
Having RV issues? Connect with others who have been in your shoes.24,394 PostsLatest Activity: Jun 18, 2026
