MEXICOWANDERER
Nov 14, 2018Explorer
Absorbsion Charging Wet Batteries
As batteries charge, amperage will sag and voltage climbs. There is a point where solar panels can effectively replace a running generator.
Use 14.8 voltage to start out with on the generator. If you have 40 amperes max DELIVERED panel power you can shut the generator off once amperage sags to 40 amps.
