havasu
Aug 23, 2013Explorer
Had this problem on my old Monaco. It had an oiler located on the bearing that was visible after removing the shroud. Use a thin oil to fill the housing which had a piece of felt inside.
On the newer AC the oiler wasn't there (cost saving???) and so I ordered a replacement fan unit from eBay - took about 30 minutes to replace. Hardest part is removing the squirrel cage fan - there is a cutout in one of the blades that you insert a long thin blade into to undo the screw that holds it in place.
