starcraft69
Jun 16, 2019Explorer
Chris Bryant wrote:
The relay on the circuit board is welded closed- he can try whacking it sharply, but it probably needs replacing.
This is more then likely the problem. From on top of the rig at the AC unit you can jump the two thermostat wires to get the unit to run. then un jumper them to get the unit to shut off. If the unit still runs then look at the relay on the board. if it shuts down after you remove the jump then Thermostat.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
