Joe417
Jun 16, 2019Explorer
I've had it happen on two different units. Both were the compressor relay.
It could be the thermostat also. If you disconnect the compressor wire on the back of the thermostat you will know which is the problem.
The relays are cheap if you can solder, otherwise it would require the whole control board.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 05, 2026
