WDP
May 13, 2014Explorer
If the cap is the same as line voltage, you have a bad connection. Use the voltmeter to verify you have 115 volts to the trailer, plug into any receptacle. Turn on the AC, does the voltage drop? If yes, check the incoming line connections in the panel, clean and tighten. If no, check the line at the compressor, low voltage, check the connections at both sides of the breaker, throw it off-on a few times, recheck. Best guess, one of the above will fix it.
WDP
WDP
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
