Chris_Bryant
May 13, 2014Explorer II
A couple of things to check- ground the yellow control wire to make sure the box is getting the right signal. Also disconnect the blue plug to the freeze control- a bad one would keep the compressor from running.
And- across the capacitors is not the place to check voltage.
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
