dclark1946
Aug 21, 2020Explorer
wa8yxm wrote:
Well... I have an evaporative assist for one of my A/C's and so far it's being a bit of a problem (NOTE it is home made) I plan on an "Advanced Design" but have not yet ordered the part needed. More on that in a bit.
The system I have is a 1/4" plastic line to where I can hook up to it and a Mister nozzle in the top end 1/2 Gallon per hour Nozzle keeps plugging up (I need to go swap out the nozzles and blow it out ... again..)
I've also used a "Flex Mister" (two mister nozzles 1 GPH) In fact that's where I got the nozzle that's clogging.. I have two of 'em one flexible one not.
Click here to see what I'm yammering about.
I decided to not pursue the misting approach partially due to the issues you mentioned as well as mineral buildup on the condenser coils. I would however be interested in any test data you can share with/without misters vs temp.
