pianotuna
Aug 22, 2020Nomad III
dclark1946 wrote:
I don't understand how any kind of evaporative cooler can function to lower temperature in a closed environment regardless of where it is located. The cooling process adds moisture to the air raising the interior humidity and if it is just recirculating it keeps adding more humidity to the air reducing the cooling. To me it seems somewhat similar to operating a window A/C unit totally inside your closed RV with the cooled evaporator air and heated condenser air both being blown into your RV.
Then you don't understand that when water evaporates the temperature is lowered.
It is NOT at all similar to a window A/C operating inside.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 14, 2026
