dsmith3's avatar
dsmith3
AC evaporator coil freezing up
Good afternoon -
First-time RV owners... We have a 2015 Jayco JayFlight 32BHDS that we took delivery on in December. It has two Coleman Mach rooftop AC units (15K BTU main ducted unit with wall-mounted thermostat and a 13.5K BTU unit in front bedroom with controls in shroud at ceiling integrated with unit). We've camped several times using AC with no problems.
Last weekend I was running only the main 15K ducted unit and it ran most of the afternoon and night. The next morning no air was coming out of ducts. Upon inspection I found that my evaporator coil had iced up. We shut it down and just ran the 13.5K front unit Sat and Sunday. Both evap and condenser coils are pristine (as you would expect on new trailer).
Could this just be normal reaction to user (me) violating "best RV AC practices"? We had thermostat set pretty low (65-70) and nighttime temps outside got down into the 60s. Fan was on Auto and unit ran pretty much constantly. From all I've read online since we got back it sounds like I should have had thermostat set higher (ex. 78) and had fan set to "On" (instead of Auto) and "High".
Appreciate any tips and advice.
Having RV issues? Connect with others who have been in your shoes.24,364 PostsLatest Activity: Mar 07, 2026
