STANG23L's avatar
STANG23L
A/C excessive noise/buffeting
Fired up the A/C in my 274VFK for the first time this week. And boy does it make a racket. Previous camper did not have A/C but I'd think that it would be on par with a house window unit as far as noise is concerned.
This thing is loud & vibrates the entire camper. Then add the fact that a couple of the roof ducts. Produce a buffeting noise that is just as bad as cracking a window in your car.
I'm guessing this is not normal. Any ideas what is going on or items I should check?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Things I have seen (NOTE that I am not an RV service tech so I've not seen that many A/Cs)
    Insect nest on fan blade causing unbalance and vibration (The "Vibrates the entire rig is a clue here) solution Clean fan blades.
    Broken fan (The fan by the way is the Condenser fan.. The other one I call a blower)
    Cracked Blower Causing rattle (And it was late Friday. hotter than. Well it was hot. and that thing was noisy. NO chance of a new blower till Monday.. I had a spare in my basement. OEM no less Worked out well. I still have a spare left. Won't ever use it less it happens again) this was a neighbor's RV. the other two were my Bedroom unit.
    The nest and the broken fan very vibrating. Shook entire RV when the fan blew
    The insect next was found in "Spring cleaning" so no problem.
Having RV issues? Connect with others who have been in your shoes.24,187 PostsLatest Activity: Jan 14, 2025
