Sam_Spade
Jul 12, 2016Explorer
greenrvgreen wrote:
I may just try a heat bulb inside the AC ceiling intake!
YOu still aren't getting the most basic "fix", which is simply to get the unit to run somewhat longer AND cut the fan off when the compressor shuts off.
To be comfortable you only need the temp AND the humidity to drop a little bit. You don't need it to be 60 degrees and 40 percent.
For that you do three things:
Make sure that the outlets are not blowing on the the thermostat.
Turn down the stat a few degrees.
Put it on "auto" so that the fan won't run without the compressor and re-distribute the water.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
