dougrainer
Jan 19, 2013Nomad
The AC compressor is NOT on. Your AC FAN is ON. READ the directions for the wall tstat. You MUST set the FAN on the wall tstat to AUTO. If you do NOT, then the roof AC Fan will come on in either LO of Hi depending on what the wall tstat is set at. Dometic does this to help circulate the furnace air in the RV. Doug
