Marsland
May 09, 2013Explorer
Micheal
I know this is an old post but if you haven't solved your problem yet here is one solution;
With regards to your thermostat, I had a salesman/manager show me how to reset the system if both AC and furnace fans came on together.
Cycle thermostat to off (no display), press and hold the + button first and without releasing it press the on/off button and hold. After a few seconds the display will indicate --. Release both buttons and then press the on/off button to turn off the system. In the thermostat manual this is called the 'System Initialization' which should have been performed by the installer.
Hope this helps.
Hope this helps.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
