down_home
Aug 27, 2020Explorer II
Thinking about all of what you said, I think low voltage..and other things, like age has taken it.
Our rear unit is a Mach. 16 years on the coach and cold as ice. They should have put more vents along the edges of the room too. That is another subject.
Our front unit or number 2 started with the same symptoms plus noise. heat portion quit but ac worked fine for a bit.Everyone said they do not make a replacement for the unit that will integrate with the existing thermostat and control panel....but Turners found one from Coleman that is a the next highest output and is even colder and more flow and quieter. Eight hundred installed or there abouts so don't sweat it.
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
