C_Schomer
Aug 27, 2020Explorer
I missed that it has a tap valve... not a good sign. It's also not good to be putting refrigerant into the low side without seeing what the high side is doing. Occasionally, a restricted drier, if it even has one, or restricted cap tube will starve the evap, so only going by the low side reading is bad. IF it leaks on the low side and goes into a vacuum air will be sucked in and it ends up in the condenser and raises head pressure. Craig
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
