dougrainer wrote:
Sorry, I meant to state AUTO/COOL. I would suspect one of the capacitors. Have you checked the upper capacitor box for shorted/burnt wires? Also, have you checked the MOUNT for the Condenser Fan. See if the mount and motor is loose or the mount studs have broken loose. Check to 120 FEED wire to the upper control box. Since BOTH units have the same noise, maybe the installer did not wire nut the Black and White 120 wires securely and they are arcing when the system has a higher amp draw. Doug
Doug I have checked all your recommend. THanks for that, but still no luck.
Something I am wondering is, the original AC units on this coach were model 47024-879. But someone replaced the two that giving me issues with model # 47224A879. Could this model have a control panel that is not compatible with my system and thus be causing the improper running of these two units?
