OK, this just started acting up, today. Have the dual roof air with a DuoTherm Comfort Control thermostat. The front (zone 1) unit is now wanting to run almost continuously even though the outside tem...
Well, it does appear to be the tstat sensor and, yes, it is set up like the older Monacos that you mentioned. Right up front under the TV box and very close to the gigantic heat conducting windshield. I made sure I closed the curtains and it really helped but I will probably put some reflectix behind the curtains. Is there an easy way to move the sensor? The wiring is all hidden and I wouldn't be clear as to where to route things. Maybe a wireless sensor?
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
