OK, this just started acting up, today. Have the dual roof air with a DuoTherm Comfort Control thermostat. The front (zone 1) unit is now wanting to run almost continuously even though the outside tem...
Doug is spot on as usual. The old one unplugs inside the AC inside the rv on mine. An easy was to tell is just unplug one of the little phone type plugs while the ac is running and it will stop immediately. Of course this is on mine.
I actually poked the little head of the sensor out from under my ac shroud on the opposite side of the intake. I do not have any exits from my AC except the ducted ones. It works great there. Mounting one somewhere would be nearly impossible.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
