MFL
Feb 11, 2015Nomad II
dougrainer wrote:
Probably no damage. But the 14 inch square hole the AC covers does not have a tolerance for a AC out of square. So, on your unit you just loosen the 4 mount bolts and then align the roof AC and then retighten the bolts. Doug
I agree with Doug. If you just lightly bumped, moved slightly, you should be okay.
The 4 bolts under inside cover should not be real tight to start with. You may have to still loosen a little, to realign AC, and maybe the gasket.
Once moved back, just SNUG up the bolts. I'd check it closely after being in the rain. If any leak, a new gasket may be the next step.
Good luck,
Jerry
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
