trailerbikecamp
Feb 11, 2015Explorer
j-d wrote:
How do those door springs get compressed? Could you make a "prop" that'd push the door up into its otherwise overextended position? I'm thinking of a length of electrical conduit or a 2x4 cut to the length that pushes the door up to a safe height. You'd move the RV only if the prop was in place.
The door is manual chain operated. To compress the springs, I have to pull a little harder on the chain that operates the door. Then there is a notched holder that one of the chain links slides into.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
