Huntindog
Feb 12, 2015Explorer
TucsonJim wrote:NO!!! Water can cause damage. Whether from rain, or a sprinkler.
I'd loosen the mounting bolts, reposition, then put a sprinkler on the roof for a while to check for leaks. If you don't have any leaks and the unit is functioning okay, you're good to go.
I would pull the unit, inspect the area for damage, fix as needed and install a NEW gasket.
If you want to check for leaks, have the unit pressure tested.
Having RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
