acritzer wrote:
ChooChooMan74 wrote:
AC will only work while connected to shore A/C power. You will have to test to see if your Tow Vehicle is supplying power to your trailer. If it wasn't equipped with a tow package, then someone would have to run a power wire. If it does have a tow package, sometimes a relay or fuse needs to be installed.
Ok thanks. The wiring was installed second hand, by Uhaul. Not exactly sure what they did except that it's a 7 pin.
Would it be worth adding to run the fridge? I'm not totally confident that it runs correctly on propane.
if you do any traveling, I would have a charge line to the trailer. If you are continuously draining your battery too much, it shortens its life.
