roadjunkie
May 18, 2017Explorer
AC Needs A Push
After I shut the AC off on my TT, I have to give the fan a spin to start it back up. After it's going, it runs and cools fine. Any suggestions?
RoyB wrote:
This could also be a low 120VAc condition. You did not mention if this was a home hookup to your house/garage setup or at a camp ground pedestal...
If you are using one of your garage 120VAc connections it may need to be a 20AMP service and the adapter should always the long dog bone type adapter available from WALMART.
RV30A to 15A long dog bone adapter
If an extension cord is being used it should be a good HD contractor 10-GAUGE type. If the extension cord is one of those red-orange type cords from WALMART then this could do what your describing. Continuing to use an under rated cord will eventually burn up connections or worse yet do damage to your air conditioner.
I have one of these RV 120VAC Meters plugged into a receptacle inside my trailer where i can glance at it to see what the 120VAC level is before I turn on my Air conditioner here at the back yard. This meter has the safe zone printed in GREEN on the front scale...
Just saying...
Roy Ken
