When I'm using shore power my air (13500) dose not seem to cool down my unit. I turn it on and it runs until the sun sets. I turned it on in the driveway using the Gen. and placed a thermometer in the...
Perhaps where you were camping had low voltage and would not allow the compressor to start or run under brown conditions. The panel connection would be the same with shore power or transferred to gen so if the AC works well with the gen then I would be inclined to say it was the pedestal where you camped. Check the wiring coming into the panel from Shore and make sure all connections are tight. What happens when you plug in at home?
Having RV issues? Connect with others who have been in your shoes.24,398 PostsLatest Activity: Jul 02, 2026
