hotpepperkidExplorerAug 04, 2016AC not coolingIt is a Colman 15K and it is not putting out any cold air. What are things I should check before I take it somewhere to have checked out
mkirschNomad IIAug 04, 2016All they'll do when you take it somewhere is tell you that the unit is not serviceable, and it must be replaced.Is the compressor running when you turn it to max cool?
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,363 PostsLatest Activity: Mar 04, 2026
Related ContentNorcold 1210 Not CoolingAC doesn't coolRooftop AC Unit Not Cooling WellCool Cat AC/Heat pump, not coolingAC not cooling
