Dr_Bob's avatar
Dr_Bob
A/C not working
The A/C isn't working neither is the fan. I can hear a slight click but nothing turns. I went to the roof and checked the fan there and it turns fine by hand. any idea where I should start?
Thanks in advance.
  • Have you checked the A/C 110v. breaker in your control panel? Also the thermostat requires 12v. to control the A/C - Do your 12v. lights work. Maybe your battery is not recharging?
  • Make and model of rig? 30 or 50 amp shore power?
    It could be loss of power to the AC unit. Check your circuit breakers. I would turn them all off with light pressure toward off, then turn them back on one at a time starting with the main if equipped followed by branch breakers.
Having RV issues? Connect with others who have been in your shoes.24,369 PostsLatest Activity: Mar 12, 2026
