MickD's avatar
MickD
AC or generator???
I have a Duo-Therm 600 series air conditioner that runs fine on shore power but when I try to run in off the gen it kills the generator. Should I look at the AC? Like the start capacitor. Or look at the Generator?
Thanks for any help.
  • Have you gone up top and checked out the wiring and capacitors? Have you tried cleaning the condenser and evaporator coils? Have you cleaned the air filters? Best to rule out the basics before opening up the wallet.
    Edit - that's the hard start capacitor that I purchased for my older Coleman 13.5 air conditioner. Worked fine, simple install, and helped.
  • MickD wrote:
    dan-nickie wrote:
    Turn your water heater off.
    Or switch it to propane.
    WHAT??? What makes you think I have my water heater on? DUH!
    Are you sure you don't have it on electric? :)
  • It's been about 4 days without a reply so I guess you resolved the issue?
    Did you switch the water heater off of electric? :)
Having RV issues? Connect with others who have been in your shoes.24,190 PostsLatest Activity: Jan 19, 2025
