MrWizard
Aug 06, 2019Moderator
sounds like the generator is over heating
used the oem generator compartment
did you add any fans for cooling to the compartment
are you running it with the compartment door open for extra air/cooling circulation
in the previous RV-ClassA DP, in order to use a portable generator
i installed a sliding tray/drawer
and mounted the genny on the tray
slide out to use, slide back in to store
made it easy to service, and allowed maximum fresh air cooling
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
