DrewE
Aug 06, 2019Explorer III
I think possibly you have a loose or otherwise connection somewhere in your neutral line between the generator and the air conditioner, and probably between the generator and RV electric panel's neutral bus. Check that everything is good and tight. Do this sooner rather than later as a poor connection under load is a hot connection (hot as in high temperature).
Having RV issues? Connect with others who have been in your shoes.24,370 PostsLatest Activity: Mar 16, 2026
