Dingy941
Aug 06, 2019Explorer
DrewE wrote:
I think possibly you have a loose or otherwise connection somewhere in your neutral line between the generator and the air conditioner, and probably between the generator and RV electric panel's neutral bus. Check that everything is good and tight. Do this sooner rather than later as a poor connection under load is a hot connection (hot as in high temperature).
I have not found any loose connections or broken wires or anything yet, I figure a short between neutral and ground would cause a break to trip either on my generator or the RV main panel, which is not the case. I will double check things though and look for any shorts between Hot Nuetral and Ground.
Having RV issues? Connect with others who have been in your shoes.24,408 PostsLatest Activity: Aug 20, 2026
