After driving rv on a couple errands I hooked up shore power as usual to house but this time blew house breaker. Tried another outlet, same thing. Shut main breaker in rv and plugged in again and have...
And you're not carifying your house plug situation. If every house plug you've used is on a GFCI circuit then the problem may be related to a "ground fault" vs over 20A current.
The unanswered questions can help to isolate the probem.
Having RV issues? Connect with others who have been in your shoes.24,409 PostsLatest Activity: Aug 27, 2026
