After driving rv on a couple errands I hooked up shore power as usual to house but this time blew house breaker. Tried another outlet, same thing. Shut main breaker in rv and plugged in again and have...
Found out portable appliance outlet only needs to be on when inverter is in use. All other electronics are fine. Still not sure how gfci blew in galley and will try and trace wires checking for continuity. A quicker solution is to run wires to it from another outlet close by. Yes, no? I will now leave off breaker that feeds it from inverter. Inverter does not show power to any outlets when running. output from inverter reads 110.8. Any further suggestions?
