After driving rv on a couple errands I hooked up shore power as usual to house but this time blew house breaker. Tried another outlet, same thing. Shut main breaker in rv and plugged in again and have...
Fridge 120v electric heating element Look at the stack/tube going up the side of the fridge from the burner You will find two black wires sticking out and going to the control board That is the 120v 340watt heating element that makes the fridge work when using electric power instead of the propane flame, Sometimes they develop a current leak to the metal case of the element which is screwed into the stack, This grounds the 120v electric you get a gfi trip or a circuit breaker trip
