I have a 2013 crossroads zinger issue is the a/c is not cooling its blowing and the compressor is coming on. could this be low Freon or do I need to look somewhere else thanks for any help
When compressor is running and is not cooling it is low Freon or bad compressor. Ufortunately there is no easy way to test as AC are build without valves. You need to add a valve for testing. Those go for about $10 on ebay.
Having RV issues? Connect with others who have been in your shoes.24,405 PostsLatest Activity: Aug 13, 2026
