Bob Landry wrote:
joe0508 wrote:
donn0128 wrote:
You likely will not be able to buy the freon, so just take it to a qualified service station and have them perform a leak test and then recharge the system. This is really not a DIY job, and needs to be done using the proper equipment by a trained and qualified service person.
Can you tell me why you dont think i will be able to buy the fron?
1993 was the magic year that everyone stopped producing R-12 equipment. With yours being a '93, it could be either R12 or R-134a. If it's R-12, it has been illegal to buy or sell R12 since 2000, so no one is going to have it. If it's R-134a, the auto parts stores are going to have it, but I'm not sure if they will sell it to you unless you have an EPA card. Also, the leak would have to be found and repaired or you will be back to recharging, and since you don't know how long it actually took it to leak down, you don't know how large the leak is or if it's repairable.
Not exactly, 93 was not the magic year.. I had a '97 F250 which was loaded with R12 and I bought that truck new.
'93 was the BEGINNING of the phase out and not all manufacturers quit using R12 over night.
As far as buying R12, you can not buy it legally unless you have a refrigeration cert/license and you must account and keep logs of where and how much is used.
There are places which you can get your system refilled with R12 but now days you might get "recovered" R12 which is filtered and recycled from old systems. Some shop owners do still have new stocks of R12 but it will often cost more than R134a.
One of the downfalls of the conversion of a system from R12 to R134a is capacity. R134a is not as efficient so it requires a bigger system in order to get the same cooling. This means a converted system will not have quit as good of cooling capacity.
How to tell if a system has been converted is R134a requires a different port connection. Retrofitted systems will have an adapter attached to the port and if I remember correctly that adapter will not come off easily.
The other thing is do not mix 134a with a system that has R12, the oils used are not compatible and all the old oil from R12 must be removed and new oil must be added to the system.
This isn't really a job for a DIY person even though you can often find change over kits.
Take it a refrigeration tech and have them go over your entire system. My suggestion is to have them replace all the o ring seals, inspect and or replace any of the rubber lines which have cracks..
Do it once the right way and you should be good to go for a long time.
