- BusskipperExplorer
GTMADNS wrote:
Just turned dash ac on this past weekend. It blows cool but not cold like it used to. Is it easy to charge yourself? This is a 2006 coachman cross country. Let me know your thoughts. Thanks
Having spent hundreds of Hours and Thousands of DOLLARS - I've just fired up the Generator - turned on the roof air.
Just too long a run with too much to go Wrong.
Beginning of every season I'll just give it a charge - Wally Chargehttps://www.walmart.com/ip/Deluxe-R-134a-Recharge-Hose-and-Gauge/16888796
Seems to last a little longer than the $2,000.00 Repair that I've done more than once.
JMHO,
Going to take a long time to burn $2,000 in extra fuel for the Generator!!!!!!!!!!!!!!!! - rwynkoopExplorer
crasster wrote:
Really - while you can DIY recharge, it is BEST if you can put the system under a deep vacuum then charge. It's the proper way to get all the air out so there is more pure 134a.
How is air going to get in it, when it still has 134a under pressure.
You can top off a system without putting it to a vacuum first.
It is normal for all shaft / belt driven compressors to leak has over a long period of time. The seals leaking keeps them lubercated. Groover wrote:
Is mine the only one that has a sight glass for checking the freon? That makes it a lot easier to know when you have enough freon in the system. I wish that all AC systems had one.
The sight glass is NON functional on a 134a system. A fully charged 134a system will still have bubbles in the sight glass. Doug- GrooverExplorer IIIs mine the only one that has a sight glass for checking the freon? That makes it a lot easier to know when you have enough freon in the system. I wish that all AC systems had one.
- rgatijnet1Explorer III
RVER wrote:
I have a question related to this question. I have a gas engine, 2003 in Newmar Mountainair on Vortec engine and first time I have driven it in weather warm, enough to put A/C on in dash, NO cold air, air does circulate through dash but not cold or cool really. I bought this used of course so one thing after another but does it sound like a charge will do it? I do not want to spend lots of money to replace the system but would like to travel with A/C if possible from the dash. IF really hot I guess I could fire up the generator and run house A/C but prefer not to. ALL THOUGHTS WELCOME.
The system needs to be checked out to see if it is low on freon or has some other problem. If your system has a low pressure switch, the compressor will not come on until freon is added, but that is not the only problem that can prevent cold air from coming from an AC system. - deandecExplorerMy OTR AC system, front and rear AC from engine compressor takes 6 lbs of 134A.
The compressor was replaced about 4 years ago as were the two dryers.
After two years I now get lack of cooling each spring.
Each year I install about 1# of 134a using a gauge set to restore maximum cooling. Auto Zone will lend you a gauge set. - RVERExplorerI have a question related to this question. I have a gas engine, 2003 in Newmar Mountainair on Vortec engine and first time I have driven it in weather warm, enough to put A/C on in dash, NO cold air, air does circulate through dash but not cold or cool really. I bought this used of course so one thing after another but does it sound like a charge will do it? I do not want to spend lots of money to replace the system but would like to travel with A/C if possible from the dash. IF really hot I guess I could fire up the generator and run house A/C but prefer not to. ALL THOUGHTS WELCOME.
- GTMADNSExplorerWell found the problem the wire to the pressure switch was off Along with the drain tube for the evaporator. I assume the truck shop that did the last oil change on the engine and generator knocked them off doing the oil change. Ac blows nice and cold again.
Thanks for input. - JimM68ExplorerI did mine last year. I spent the bucks on a proper hi/lo gauge set even. Put in a can of freon. I found that the compressor was not kicking on, even though the gauges said the system was full.
Troubleshooting revealed a temp switch on the ac unit had failed. It's purpose is to cutoff the compressor before things ice up, but it was preventing the compressor from running at all.
I hot wired it.
Replacing it is on my list. - IvylogExplorer IIIAnother use of a IR temp gun... shoot the end 180 degree tubes on the AC condenser and when all but a couple of the bottom ones are about the same temp as the top ones, you have put in enough freon in the system.
On a system that is only working OK you can do the same to see if it needs a little more freon. You want the fins/tubes on top 80+ percent of the condenser hotter than the bottom ones. If only half of the condenser is hotter you are loosing a lot of cooling capability. Even my 42' DP only takes three pounds of freon.
38,783 PostsLatest Activity: Sep 10, 2026
