dubdub07
Jul 04, 2018Explorer
Diesel Pusher category
Not that this is a "mine is different so it's better" thread, but at a minimum we could get DP on the drop down to better sort the the gassers from the DPs. Not much similar in the two.
WW
WW
dougrainer wrote:
After being on various forums for almost 20 years, me thinks the call for change is a subtle form of snobbery. Yes, it would be nice to get those lower cost Gas Class A's away from the Diesel forum:B Those that made the jump to Diesel and can afford it, do not want to see or hear about any problems those low life Gassers have:B From a RV Tech standpoint, I like having Gas and Diesel on the same forum. Maybe what we really need is a CHASSIS forum, just for Diesel and Gas. A LOT of non chassis issues belong to both Diesel and Gas rigs. Doug
donkeydew wrote:
if it is not broke don't fix it.
WW
Mile High wrote:dubdub07 wrote:I personally like your idea.
WW
To me, the only thing common between a gas Class A and a Diesel Class A are the things that are common to ALL RVs, like that silly list Dale took the time to type out. Heck, a truck camper met most of that list.
Once you get to chassis, I find the gas and diesel are completely different. DPs have a lot of focus on the chassis: rear vs side radiator, tag axles, air ride suspension, air ride leveling, steering tags, aquahot or hydronic heating, diesel gens, independent front suspension, heated floors, etc. Also more predominate are the residential appliances and all electric coaches.
I would support a change, but doesn't sound like this group is open to much in the way of suggestion :)
WW
