Chris_Bryant
Jun 28, 2013Explorer II
The compressor is the motor you are sizing it for, and a 15k btu compressor is a bit over 1 hp (mol), plus the capacitor is the same size as stock (88-108 mfd).
I actually disagree with Supco as to recommending the E series- they don't, I do. The reason they do not recommend it is it will recycle immediately- if you turn the compressor off then right back on, it will kick in, whereas the PTCR type (like stock) will not. My answer is to not turn the a/c off then right back on, plus most thermostats will prevent this.
My reason for recommending the E series is that running on a generator, the generator will sag briefly. The E series has a "potential" type relay which will keep the capacitor in the circuit until the compressor is running at 75% of speed. The original PTCR type (which the non-E series are) are time based, so they drop out even if the compressor is not running at speed.
The SPP6 is functionally identical to the stock Coleman start kit anyway.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: Apr 10, 2025
