sayoung
Sep 18, 2017Explorer
Mandalay Parr wrote:
One more test you might try is to disconnect both motor leads and ohm out the motor making sure the motor is not open.
If seized thermal overload opens in most cases so appears as an open winding. If tripping breaker then you need to check if compressor windings now have continuity to GND & you need an ohmmeter that has MEG-ohms range .
You might get lucky & just be loose connection at breaker.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Aug 12, 2013
