57_Panhead
Sep 19, 2017Explorer
AC Still not working---Update---
First, Thanks to all who suggested possible problems to check on my Coleman Mach 15,000 AC unit. So I checked the start and run capacitors and they are in spec. To be sure I even swapped them out with new ones and no change.  Checked all wiring and no loose wires. Swapped circuit breakers and still no change.  There is 115 Volts at the wire where it connects to the compressor but it wont start.  Is it likely that the compressor has seized up on a unit that is only 5.5 years old and has not seen very much use?
So now I ask, is it fixable or am I better off just buying a new unit?
Your opinions please.
Thanks
Steve
Thanks
Steve
