Ronhoward's avatar
Ronhoward
ac temp.
my 15500 btu ac is duct in but has a dump so you can cool the living area 1st. I was wondering what the temp should be if I stuck a thermometer in the dump or air flow? This is not a year old yet and 5th wheel is 34' long
  • marcsbigfoot20b27 wrote:
    You guys saying 14-20 must be talking residential AC.
    I just went out to my trailer 13,500 btu, ambient temp 74 F outside, important for condenser cooling.
    Inside trailer 80 F. Turned AC on max, intake air at filter 74 (after 5 minutes) cold discharge air was 42 F. Switched to low fan, 38F. Both were dropping every minute.
    That of course was at 8% humidity.
    Car, RV, or residential doesn't make any difference.
    You put a thermometer at the intake of the unit. Then put the same thermometer at the output. Normal is a 14 - 20 degree drop. This should be done after it has run for a while and temperatures have stabilized.
    I just went out to my trailer 13,500 btu, ambient temp 74 F outside....important for condenser cooling.
    While the ultra low humidity plays a huge part, even with that a drop of that much indicates air recircualtion. The new R401 (on edit- that's R410a, not R401) units average in the upper teens, older R22 units were 20. More if dry, less if humid.
  • beemerphile1 wrote:
    The temperature differential between incoming air and outgoing air should be 14 to 20 degrees.
    A properly running A/C unit should have a
    temperature difference of approximately 16 to
    22°. Slightly lower temperature differences
    are possible under extremely humid
    conditions. (The unit may have to run longer
    to remove moisture.) Greater temperature
    differences than 22° are possible in hot dry
    weather
    You MUST have ambient temps over 75 degrees to do this type test. Doug
  • You guys saying 14-20 must be talking residential AC.
  • The temperature differential between incoming air and outgoing air should be 14 to 20 degrees.
  • j-d's avatar
    j-d
    Explorer II
    We usually think of A/C performance as "split." Split means how much lower the discharge temperature is below the return air temperature. Others may have better numbers, A/C on when your stored RV is 100* inside. If it's discharging 80* that's a good split. But if you want it to be 70* in your RV, you won't see 70* discharge air till the whole thing is cool enough inside for the return air to be 90*.
    Depending on how much you've used the RV and where, you can get some split back by cleaning the unit. Here's How.
Having RV issues? Connect with others who have been in your shoes.24,318 PostsLatest Activity: Sep 14, 2025
